> > Marian Zurek
> > CERN
> Hi Marian,
> I finally looked closely at the dfanout which is in the EPICS
> distribution. All of the values (including of course HOPR and LOPR)
> are defined as long integers. This explains why you get an error
> when you try to set HOPR to .5 from the opi.
> Does any one else have a copy of a floating point data fanout already?
> Good Luck,
> Rozelle
The "sequence" record can work as a data fanout for floating point numbers.
There are 10 "put" links, and each one can get data from a different PV. If
all of the inputs are defined the same, you have a data fanout. You also
get the added bonus of specifying a delay between link execution.
Ned
Re: User's Guide on EPICS Build System Marty Kraimer
Re: Should dfanout be called dLoFanout? Johnny Tang
<1996>
2025
2026
Should dfanout be called dLoFanout? Rozelle Wright
Re: Should dfanout be called dLoFanout? William Lupton
<1996>
2025
2026
