1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Waveform digitizer
To: [email protected]
Date: Fri, 20 Dec 1996 11:13:51 -0600
	I've need for a high speed waveform digitizer with the following
features:
	8-bit resolution
	1296 or greater sample memory
	Analog Bandwidth >350 MHz
	Ext. Trigger Input, Rate = 2Hz
	Ext sample clock input: 352MHz
	Waveform readout rate: 2Hz min
We want to digitize our bunch current at the rf frequency (352MHz), hence need
an external trigger and an external clock.  VME card is preferable, but
will consider other options. Epics support would be nice, but not necessary as
we'll just write our own if necessary.
Happy Holidays,
Frank
Frank Lenkszus	 [email protected]  (708) 252-6972
Advanced Photon Source -- Controls --  Argonne National Laboratory
Prev: Re: Should dfanout be called dLoFanout? William Lupton
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Should dfanout be called dLoFanout? Johnny Tang
