(response to Marty's comments)
>Chip has also requested that CA gets/puts also have priorities. (I think
>I recall this also being discussed previously by Jeff and others.)
>This means multiple priority CA server tasks.
>Should any of these priorities be higher than any of the scan tasks?
Should be user configurable. I.e., 3 priorities (high, medium, low) with the
priorities of those servers configurable with respect to the priorities of
the proposed High, Medium, Low scan tasks. My first guess would be to
interleave them (SCAN, CA, SCAN, CA, SCAN, CA). If we used only a single
server I would configure as (SCAN, CA, SCAN, SCAN), so that the application
developer has a place to put his semi-hard requirements above channel
access activity.
>2) Setting CA UDP and CA TCP to high priority.
>This is not a good way to solve the slow connection problem.
>Processing CA search requests can, for short periods of time,
>put a significant load on an IOC. This make it extremely
>difficult or impossible for the application developer
>to test that the performance requirements are meet.
>I seems strange that a high priority real time requirement for
>an IOC is to make a new operator screen quickly connect.
>If this was truly a time critical screeen why wasn't to already
>up and running when it was needed?
Operator response is a high priority requirement for all screens, and there
are too many to keep up all the time. To address your concern, and still
keep the performance, there are two solutions:
1) move name resolution off to another (redundant) process on Unix; probably
configurable so those who don't want to manage their namespace don't have
to.
2) use the CA gateway to front most or all clients, and have the gateway
have LONG timeouts on dropping an unused channel. This unloads most of
the connect and monitoring load off of the ioc, making it more real
time
The second option is pretty much available today, and the first has been
discussed for several years at low priority.
Chip
- Re: flaky IOC problems at Jefferson Lab Marty Kraimer
Re: flaky IOC problems at Jefferson Lab watson
PC/WIN32 Display Options Kay-Uwe Kasemir
<1997>
2025
2026
Re: flaky IOC problems at Jefferson Lab Bill Brown
<1997>
2025
2026
