Subject: |
Display Manager ASCII Formats |
Kay-Uwe Kasemir <[email protected]> |
Date: |
Fri, 24 Jan 1997 15:07:44 -0700 |
Hi Chip, hi all:
After hearing that EDM uses an ASCII format that is 'new', Chip wrote:
>Well, I'm rather disheartened to hear of yet-another-ascii format being
>created to describe displays.
>While you may not have liked the old
>format, the cost of incompatibility is quite high (which you probably
>cannot appreciate having not been on the project long enough). Can
>you post your reasons for creating a new format to tech-talk?
Well, I've been into this about as long as the DESY people are
and I do understand that every new format is a pain,
but what format would you pick?
I was thinking about using edd/dm, but ADL is no 'generic
display description language'. Instead it is heavily related to
the way edd/dm maintains it's internal structures.
So for edd/dm it's very easy to read/write, for my display
manager it would be a maijor effort to implement that format.
So what I use right now is a tagged printout of my
Implementing this _and_ a basic converter from edd/dm
into my format took only two days, so that's what I did
instead of spending much more time implementing a format
that doesn't fit my needs and isn't generic, either.
If all display tools should use the same format,
we must try to find a generic format that makes
sense, with extensions for each specific DM which
are ignored by the remaining programs.
Forcing all tools to use edd or medm or some other
format which is heavily related to a single program
seems to be no good idea to me.
Meanwhile we have to use converters.
-Kay
For what it's worth: an example:
# Saved: Wed, Jan 15 1997, 13:05:11
# Object Count: 18
Bitmap
Object
rect=218 8 575 88
color=0x000000
keep_size=0
Label
Object
rect=5 140 170 173
color=0x000080
Font
name=Courier New
height=33
weight=400
pitch=49
txt=IP-16 ADC
Bar
Object
rect=12 193 133 218
color=0x0000FF
pv=ioc1:ADC0
TextUpdate
Object
rect=46 221 106 240
color=0x000000
pv=ioc1:ADC0
Font
name=Fixedsys
height=19
weight=400
pitch=49
txt=1.7004
Re: PC/WIN32 Display Options watson
FWD: Display Manager ASCII Formats Matthias Clausen DESY -MKS-2/KRYK-
<1997>
2025
2026
Joerger `VDACM' 8ch/16bit waveform generator SARKAR
<1997>
2025
2026
