I recently built dct313 (the most recent release) and noticed the
following two problems:
Problem #1:
I use dct313 to create a simple database containing just a couple of
ai records. On the left side of the main dct313 window
(left-pane) I see the names of the records in the database.
On the right side of the main dct313 window
(right-pane) I see the fields/values for one of the database records.
By clicking on the name of a record (in the
left-pane), the right-pane is re-drawn in order to display the
fields/values for this record.
So far so good.
The problem is that, when I click on a record-name (in the left-pane) and
then QUICKLY (before the fields of this record are drawn on the
screen) click on another record, I get the following message:
Error:window
"userFrame.fieldDialog.userFrame.scrolledFieldList.frame.canvas.frame.item37"
was deleted before its visibility changed
The stack-trace reveals that the error occurs while executing the
command:
"tkwait visibility $w.item[expr $i - 1]"
The source code around this command goes like this:
---- Source code from: dct.tcl ------------------
# tkwait needed for proper timing of widget display ... without it code fails
if {"$i" > "0"} { tkwait visibility $w.item[expr $i - 1] }
APSScrollAdjust .userFrame.fieldDialog.userFrame.scrolledFieldList -numVisible 11
set status [DCTdbFirstFielddes]
---- End of source code. ------------------------
I noticed that if I rewrite the command
as:
if {"$i" > "0"} {catch {tkwait visibility $w.item[expr $i - 1] }}
everything seems to work fine.
Any comments?
Problem #2: (This looks more like "lack of feature", than a bug)
It seems to me that there is no way to make the INP field of an "ai" record
point to another record.
I can see the INP field in the right-pane, and next to it there is a
text-entry-box and a button labeled "Form". But there is no
"To PV"/"To Const." button.
Is this supposed to happen?
Sincerely
Nick Patavalis
([email protected])
Inst. for Accelerating Systems and Apps.
Athens Jan 28, 1997.
PS. I use tcl v7.5 and tk v4.1.
Re: digitizer needed Ned Arnold
ADD [email protected] Richard J. McCarthy
<1997>
2025
2026
next training at LANL - April 21st Bob Dalesio
<1997>
2025
2026
