1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Make, Scripts, Shell, Perl!?
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Mon, 03 Feb 1997 16:57:51 -0700
Tim Mooney wrote:
> > Perl is a possibility here, but I think TCL is probably a better choice.
> > However, I'd like to propose Python as an even better choice.
> In my opinion, neither Perl not tcl are appropriate languages for this
> purpose because their syntaxes are just too weird and too strewn with
> subtle gotchas for casual use.  What I've seen of Python looks very
> good (except for that stupid business of using indentation alone to do
> what C does with curly braces.)
As I understand it, perl has text/file/path manipulation
capabilities far beyond what is available in most scripting
languages. These text process capabilities are needed if we
are to replace the use of sed, awk, ... in the EPICS build and
consolidate on one additional installed product (perhaps
perl). These changes would allow us to build EPICS on
NT, VMS, ... with only the EPICS build system, perl, and gnu make.
At the risk of being flamed I will repeat some rumors I have heard:
perl:
	utilitarian and widely used - special text
	processing, path parsing, and other system adm stuff.
	Inherits syntax peculiarities from awk?
java:
	single inheritance
	(compiler required if not java script -
	does this have text/file/path manipulation support
	comparable to perl? )
python:
	multiple inheritance
	(does this have text/file/path manipulation support
	comparable to perl?)
tcl:
	pre-processor heavy
	(doest this have text/file/path manipulation support
I must admit that I program mostly in C/C++ rather than in
scripting languages and so I am far from an expert in this area.
Please feel free to enhance/correct the above comparison so that
we can make an informed choice.
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Re: Make, Scripts, Shell, Perl!? watson
Re: Make, Scripts, Shell, Perl!? Tim Mooney
Prev: Re: Make, Scripts, Shell, Perl!? Gary Carr
Next: Re: Make, Scripts, Shell, Perl!? watson
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Make, Scripts, Shell, Perl!? Tim Mooney
