1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Make, Scripts, Shell, Perl!?
To: Richard Wolff <[email protected]>
Cc: [email protected]
Date: Wed, 05 Feb 1997 10:19:10 -0700
Richard Wolff wrote:
> Hmmm...looks like a suitable challenge here.  I'll try to do something
> on this with Python in the next week, after the current bits of chaos
> around here are scheduled to subside.
If you get started on this we should make sure that you are working
with the same version of EPICS as Kay. We have recently
(this fall) moved some of the shell based stuff into gnu make.
Sorry to go ahead with a perl prototype prior to the end
of the discussion. We must move quickly because Kay's last
day here is Feb 21 (after which he is returning to Germany)
- and he is the only one of us that really knows perl at
this point. Also, if this change makes it into 3.13 then
the NT port will be much easier to install, and we are very
close to making an official release of 3.13.
At this point there are a fairly small number of scripts that
need to be replaced. As I recall Kay mentioned that he has
3 days into this so far.
I think that it is safe to say that the advantages of object
oriented programming are most relevant to large projects with
many lines of code. Do you see a practical advantage of python
over perl considering that most of the projects written in
scripting languages are likely to be smaller in scope?
Can anyone else comment on there preference/tolerance/revulsion
of/for python before Richard gets started?
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Re: Make, Scripts, Shell, Perl!? Richard Wolff
Prev: [no subject] W.-D. Klotz
Next: Re: Make, Scripts, Shell, Perl!? Richard Wolff
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Make, Scripts, Shell, Perl!? Richard Wolff
