> From [email protected] Tue Feb 25 18:42:33 1997
> Return-Path: <[email protected]>
> Date: Tue, 25 Feb 1997 15:39:58 -1000 (HST)
> To: [email protected]
> Subject: Archiving question(s)
> Cc: [email protected]
> Mime-Version: 1.0
> Content-Type> : > text/plain> ; > charset=us-ascii>
> Content-Transfer-Encoding: 7bit
> Content-Md5: l9Yb5y/+c32OmqgL7cpURg==
> Content-Length: 716
> X-Lines: 23
> After first consulting the "Phrase Finder" and then Nick I am
> still stuck trying to get AR to archive any data.
> Following questions:
> - In our current (test) setup the channel values don't change. I read
> that setting ADEL to a negative value should overcome the non-archiving
> of constant channels, but it still doesn't. AR doesn't complain about
> the .req file, connections are established, it just doesn't write a file.
> Any ideas why?
> - Which way is archiving going?
> The latest version of AR we have came with 3.13.0.alpha3.
> There is archiving effort at DESY.
> There is the frequency archiver.
> As we don't have any EPICS archiving experience here, we could
> go either way.
> Thanks in advance,
> Maren Purves
> UKIRT
Hi Maren,
Do you have at least one of your channels that is always changing?
If not, make yourself a counter and add it to the list. Then
make all the rest of your channels filled. I think you must add
an F to the beginning of the request.
The current AR archiver is set up so that it will only archive when at
least one channel has changed.
Rozelle
|Rozelle Wright Phone (505) 667-4804 |
|Los Alamos Natl Labs AOT-8 FAX (505) 665-5107 |
|PO Box 1663 MS-H820 Group Office (505) 667-6087|
|Los Alamos, NM 87545 email : [email protected] |
Re: Archiving question(s) Chip Watson
Re: Archiving question(s) Matthias Clausen DESY -MKS-2/KRYK-
<1997>
2025
2026
<1997>
2025
2026
