David Terrett wrote:
> I have just discovered the VxWorks "checkStack" command and find that
> after loading my system, bringing up a couple of dm screens and setting a
> couple of process variables one of the lines of output from checkStack
> reads:
> CA client _camsgtask fff138 4760 264 4760 0 OVERFLOW
> Should I be worried by this ? If so, what can I do about it ?
Yes, this indicates that your stack has grown past its allocated space
and
it will therefore be corrupting other data structures in memory. This
of course could result in a system crash.
> I also believe that I am overflowing the stack in a subroutine attached to
> a subroutine record that is being scanned periodically. How can I increase
> the stack for a scan task ?
> (I am using Epics 3.12.2)
Most likely this is caused by an unusually long string of
interconnected records in your database. When the server
(running in camsgtask) calls db_put_field() for a passive
record recursive record processing results, and this can
overflow the stack if you have a very long string of
interconnected records.
In the latest patch release or R3.12.2 the file
"$(EPICS)/base/include/task_params.h" has the following
parameters in it:
#define CA_CLIENT_STACK 10000
#define EVENTSCAN_STACK 10000
#define SCANONCE_STACK 10000
#define CALLBACK_STACK 10000
#define PERIODSCAN_STACK 10000
You might find that bumping your copy of CA_CLIENT_STACK
to 10000 resolves your problem (after you rebuild
the object codes in base and reboot the IOC).
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
- Stack overflows David Terrett
test Russell J. Page, Sr.
<1997>
2025
2026
Looking for help Todd Boroson
<1997>
2025
2026
