Subject: |
RE: Compilation error in EPICS extension |
"Lancaster, Christy A" <[email protected]> |
To: |
"'tech-talk'" <[email protected]> |
Date: |
Tue, 25 Mar 1997 09:11:33 -0800 |
I was having the same problem till I discovered that the commands for
build and install (which you will find has problems in some directories)
are duplicated between certain Makefile.Unix's and the RULES_ARCHS in
the config directory. There is a new set of extensions and config files
available as of mid-March that seem to resolve this problem. In the
meantime, if you want to fix the problem, comment out the build
statement in the Makefile.Unix and things should progress normally.
Good luck!
Christy Lancaster
Boeing Free Electron Laser
PO Box 3999 M/S 2T-50
Seattle, WA 98124
(206)544-5426
>From: Russell J. Page, Sr.[SMTP:[email protected]]
>Sent: Tuesday, March 25, 1997 7:07 AM
>To: Tech_Talk
>Subject: Compilation error in EPICS extension
>Hi:
>I am attempting to Make the EPICS R3.13.0.beta4 extensions. When I get
>to appSR, I get the following error that I have encountered both single
>and double colon entries in the rule. I understand the difference, and
>have infact fixed this type of error before. My problem is I can't find
>the error. Here is part of the make output that contains the error
>message:
>gnumake[2]: Leaving directory
>`/home/locus/epics/R3.13.0.beta4/extensions/src/alh'
>/usr/local/bin/gnumake -C appSR inc
>gnumake[2]: Entering directory
>`/home/locus/epics/R3.13.0.beta4/extensions/src/appSR'
>/usr/local/bin/gnumake -C O.sun4 -f ../Makefile.Unix T_A=sun4 inc
>gnumake[3]: Entering directory
>`/home/locus/epics/R3.13.0.beta4/extensions/src/appSR/O.sun4'
>../Makefile.Unix:190: *** target file `build' has both : and ::
>entries. Stop.
>gnumake[3]: Leaving directory
>gnumake[2]: *** [inc.sun4] Error 2
>gnumake[1]: *** [appSR.inc] Error 2
>gnumake[1]: Leaving directory
>`/home/locus/epics/R3.13.0.beta4/extensions/src'
>gnumake: *** [src.inc] Error 2
>Note that it indicates line 190 of Makefile.Unix. Note below that
>(according to my editor) 'build' occurs in line 188, not 190. I am
>however looking at everything I see connected to either line. Refer now
>to the appropriate segment of the makefile:
>INSTALL_APPSR=$(INSTALL_LOCATION_BIN)/appSR
>APPSR_INSTALL_DIRS=$(APPSR_DIRS:%=$(INSTALL_APPSR)/%)
>APPSR_INSTALL_PROD=$(APPSR_PROD:%=$(INSTALL_APPSR)/bin/$(T_A)/%)
>APPSR_INSTALL_TOOLS=$(APPSR_TOOLS:%=$(INSTALL_APPSR)/bin/$(T_A)/%)
>APPSR_INSTALL_FILES=$(APPSR_FILES:%=$(INSTALL_APPSR)/%)
>APPSR_INSTALL_SCCS_FILES=$(APPSR_SCCS_FILES:%=$(INSTALL_APPSR)/%)
>include $(EPICS)/base/config/RULES.Unix
>build: $(APPSR_PROD) <-------------------------- flagged as error
>install: $(INSTALL_LOCATION_BIN) $(INSTALL_APPSR) $(APPSR_INSTALL_DIRS)
>$(APPSR_INSTA
>LL_TOOLS) \
>$(APPSR_INSTALL_PROD) $(APPSR_INSTALL_FILES) $(APPSR_INSTALL_SCCS_FILES)
>appSRLinks
>$(INSTALL_APPSR) $(APPSR_INSTALL_DIRS) $(INSTALL_LOCATION_BIN)
> @mkdir $@
>I have looked everywhere I can think to find that double : entry, to no
>avail. Any thoughts ?
COllaboration Meeting In Vancouver Bob Dalesio
Time granularity in archive data streams Matt Bickley
<1997>
2025
2026
Compilation error in EPICS extension Russell J. Page, Sr.
Compilation error in EPICS extension Janet B. Anderson
<1997>
2025
2026
