1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: INC and install
To: [email protected]
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 27 Mar 1997 14:08:14 +0000
Russell,
Russell J. Page, Sr. wrote:
> During Make, I often find an *.h file (which is already in the same
> directory as the corresponding *.c file) being "installed" in the
> include directory above, by the makefile using "INC = file.h". It
> appears that this is not required, but rather it is an attempt by EPICS
> to keep all of it's *.h files together in one place. Question: How does
> Make 'know' where to install the *.h file ?
The main purpose of this installation of .h files is not for the
compilation of the .c file itself, but for other .c files within other
directories which call the library which is being built.  The .h file
should be kept in the source directory with the .c file to which it
refers, but can be referenced from anywhere in the base build structure
without having to have lots of -I../somewhere options.
Make installs the INC files into the directory named in the Make
variable INSTALL_INCLUDE. In base/config/CONFIG_COMMON:
	INSTALL_INCLUDE = $(INSTALL_LOCATION)/include
	INSTALL_LOCATION = $(TOP)
TOP is defined in each Makefile, and points to base.
Note that there is a base/src/include directory which is distributed
with a number of .h files in it, and contains a Makefile.Unix which
lists these in INC so they get installed.  Don't confuse this directory
with base/include which is where the .h files get installed into.
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
INC and install Russell J. Page, Sr.
Prev: RE: Rebooting an IOC Gordon Uchenick
Next: Re: Rebooting an IOC Jeff Hill
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: INC and install Russell J. Page, Sr.
Next: Rebooting an IOC SAA
