Andy Foster wrote:
> I am trying to write a program which builds a list of the
> channel id's for certain fields in a particular type of record
> in an active database.
> I can see how do to this using a program similar to
> dbDumpRecords (in the IOC developers guide) and using the
> "ca_search" routine from the CA library.
> However, when including both "dbStaticLib.h" and "cadef.h" in the
> same file, I get lots of redefinition warnings and the code does
> not compile. I got round this by creating separate files for each
> routine in my program. Should I need to do this? What am I doing wrong?
> I am using 3.12.2.
The problem is that old and new database access (db_access.h and
dbAccess.h).
use some common DBF_XXX and DBR_XXX names with different values.
Since channel access uses old database access, calls to it can not be
mixed
with code that includes dbStaticLib.h or dbAccess.h.
Sorry,
Marty
- Building a list of Channel ID's Andy Foster
Re: Capfast symbols F. Gougnaud
Re: ioc re-connect problem Alan K Biocca
<1997>
2025
2026
Re: Building a list of Channel ID's Bob Dalesio
<1997>
2025
2026
