1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Usage of OffPage Input/Output ?
To: Marian ZUREK <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 17 Apr 1997 11:41:15 +0100
Andy Foster wrote:
> An alternative to the OffPage Input/Output connectors is to use
> the hardware in/out symbols. Then specify the remote record and
> field name in the VAL property of the hardware symbol.
> Connect this up to the local record which wishes to read/write
> the remote record.
This is my favourite technique, but you need to include .PP and/or .MS
flags after the record.field name if you want the link to be anything
other than .NPP.NMS (the pproc and palrm properties of the link field do
*not* work here - I wish they did...).
Another method is to use hierarchical connectors, as covered in the
EPICS CapFast tutorial.
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
Re: Usage of OffPage Input/Output ? Andy Foster
Prev: Re: Usage of OffPage Input/Output ? Andy Foster
Next: Re: Bizarre MEDM problem Bonnie Madre
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Usage of OffPage Input/Output ? Janet Tvedt
