> From [email protected] Wed May 21 11:54:41 1997
> Return-Path: <[email protected]>
> Date: Wed, 21 May 1997 10:52:53 -0700
> To: [email protected]
> In-Reply-To: <[email protected]> ([email protected])
> Subject: 3.12.2 GetRel command
> Content-Length: 903
> X-Lines: 34
> I'm having the following command with trying to do a getrel
> with 3.12.2. According to the documentation, I should do the
> following:
> /cello/epics/R3.12.2/base/tools/getrel /cello/epics/R3.12.2
> However, when I do this command I get the following error message:
> Usage:
> getrel <EpicsNode> [arch1 arch2 ...]
> ex: getrel /usr/local/epics/R3.12
> --------- OR -----------
> getrel ~/epics mv197
> If the optional architecture list is left out links
> for supported architectures will automatically be
> created.
> /cello/epics/R3.12.2 does not appear to be an EPICS root tree...
> Does anyone have any hints as to what I'm doing wrong?
> Thanks....
> dave
> Dave Reid [email protected]
> UW Medical Center (206)548-4536
> Radiation Oncology Dept.
> Seattle, WA
I wonder if you had an error when you built epics in /cello/epics/R3.12.2?
If you look at the script getrel it checks for bin, src/ascii and rec underneath
base.
#excerpt from getrel:
EPICS=${1}
BASE=${1}/base
CONFIG=${1}/config
if [ ! -d ${BASE}/bin -o \
! -d ${BASE}/src/ascii -o \
! -d ${BASE}/rec ]; then
cat <<-!usage
$USAGE
${EPICS} does not appear to be an EPICS root tree...
I hope this helps.
Rozelle
|Rozelle Wright Phone (505) 667-4804 |
|Los Alamos Natl Labs LANSCE-8 FAX (505) 665-5107 |
|PO Box 1663 MS-H820 Group Office (505) 667-6087|
|Los Alamos, NM 87545 email : [email protected] |
3.12.2 GetRel command Dave Reid
get_precision problem Marty Kraimer
<1997>
2025
2026
stripTool Documention Graham Waters
<1997>
2025
2026
