1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS_CA_ADDR_LIST 80 character limit
To: "EPICS tech-talk mail list" <[email protected]>
Date: Thu, 22 May 1997 15:17:53 -0600
Hello All,
There is an 80 character limit on EPICS environment
variables in EPICS 3.12.2. This limit has been removed
in recent beta releases of EPICS 3.13.
For what its worth, I just discovered that
the IP address parser will also accept hexadecimal
so "0x80a520ff" results in the same IP address as
"128.165.32.255" while requiring only 10 characters
(not 14 characters). Perhaps this will assist those of you
that have hit the 80 character limit with
EPICS_CA_ADDR_LIST in 3.12.2?
It also appears that the limit on an EPICS_CA_ADDR_LIST
values obtained from getenv() (from UNIX setenv/vxWorks putenv())
can be removed by a small patch to 3.12.2 if I do not try to remove the
limit for EPICS build compiled in values and I do not address
string length limits on any of the other EPICS environment variables.
If there is interest I will add the above patch to 3.12.2
Jeff
______________________________________________________
Jeffrey O. Hill           Internet     [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Prev: stripTool Documention Graham Waters
Next: steppermotor record problems Len Lawrence
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
