1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fw: time to execute FMUL on 68k
To: "EPICS tech-talk mail list" <[email protected]>
Date: Thu, 29 May 1997 08:31:18 -0600
overheard on the vxWorks mail list....
> > Submitted-by [email protected]  Wed May 28 11:04:52 1997
> > Submitted-by: Andrew Pearce <[email protected]>
> > Hi,
> >      we have noticed that floating point operations on 68040 platforms
> > can take widely different times to execute, depending on the value of
> > the numbers being used. Below are two similar functions that illustrate
> > the behavior.  Each function multiplies two floats, but testFMul2
> > causes a floating point underflow to occur when the multiply is
> > performed.
> > Using timexN from the vxWorks shell, we see that testFMul1 takes 1 usec
> > to execute, but testFMul2 takes 26 usec to execute. The Underflow
(UNFL)
> > and Inexact (INEX) flags are set true in the Floating Point Status
> > Register.
> > Reading the chapter on the 68040 Floating Point Unit suggests that
> > the FPU is performing exception processing in an attempt to return
> > the most precise value that it can, given that an underflow has
> > occurred. This exception processing is internal to the FPU
> > and does not involve the 68040 because the exception enable bits
> > are set false by vxWorks.
> > Does anyone have experience with this problem and can tell me
> > if my reasoning is correct here? I am surprised that the
> > exception procssing seems to takes 26 times longer than the
> > multiply!
> I think you are correct here.
> > One issue for real-time systems is that the 68040 FPU conforms
> > to the IEEE 754 standard. I imagine that the goal of the standard
> > is numerical exactness so that you get the same answer regardless
> > of the platform in use. It probably doesn't say much about
> > deterministic behavior.
> > We started looking at this problem because our control system
> > would normally take 10% of the CPU, but occasionally would
> > jump up to take over 30% of the CPU.
> The problem is that the 68040`s floating point unit does the FP
> denormalization with an exception.  This is what causes your execution
> time differences.  Whenever the system needs to denormalize a small
> number, then a trap is taken.  We "solved" this problem in some of our
> systems by flushing a very small number to 0 when we see it.  You can
> see this effect if you have a control system that can drive an error
> term to 0, and there is no noise in the system, like in a simulation
> of a dynamic system.  I investigated this with Motorola, and they
> said there was no solution.  I think you could hack the 040 math
> library code (in assembly, naturally!) to flush to 0 when an
> underflow occurs.  As you point out, this causes the implementation to
> violate the IEEE 754 standard.
> Personally, I think Motorola erred in crippling the 040`s FP unit by
> moving so many instructions into firmware.
> John Ford
> National Radio Astronomy Observatory
> Green Bank, WV 24944-0002
> [email protected]
Prev: EPICS support for LAN/GPIB gateway HP E2050A Benjamin Franksen
Next: Doc on stepperMotor record Benjamin Franksen
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
