1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA and EPICS_CA_ADDR_LIST -> EPICS_CA_ADDR_FILE
From: Matthias Clausen DESY -MKS-2/KRYK- <[email protected]>
To: [email protected], [email protected]
Cc: [email protected]
Date: Fri, 30 May 1997 21:08:06 +0200 (MET-DST)
The question of getting access to remote (off subnet) IOC's is a common one.
The limit in the env. vars is maybe also good because we might end with addr-lists of too
many nodes. None the less I want to propose to add a new env. var like: EPICS_CA_ADDR_FILE
where you can enter all your IOC's you want to talk to. This might be a performance hit to
the client and therefore it should not be implemented on the IOC clinet.
Another solution might be the ca_name_server which we heared about during the EPICS
workshop and which might have another implementation based on the portable ca_server.
If this solution would be available already for 3.13 (Jeff??) many of us would not need to
argue any more about the limitations in EPICS_CA_ADDR_LIST.
Matthias
Prev: VxWorks5.2 patch2 Bakul Banerjee
Next: Re: CA and EPICS_CA_ADDR_LIST -> EPICS_CA_ADDR_FILE Jeff Hill
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
