1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDD/DM: Passing multiple arguments for color rule definition ?
To: [email protected]
Cc: [email protected], [email protected]
Date: Tue, 3 Jun 97 10:53:50 MDT
Hello Marian,
I was able to reproduce the problem you reported.  Your color rules
were defined correctly.  I'm working on the fix now.  BTW, the limit on
the number of chars allowed in an edd or dm textedit box was initially
40.  That was changed at some point to 250 in edd for the macro
substitutions.  Dm still uses 40 since MAX_STRING_SIZE in the database
is still 40.
deb
> > > In the EDD/DM I need to implement color rule which represents the
> > > highest alarm severity of two channels.
> > > Then I didn't found how to pass two or more arguments to the rule (is it
> > > possible at all ?)
> > Yes, it is possible to pass more than one argument.  However,
> > you can't directly compare one alarm severity to another since
> > the right hand terms (the terms following the comparators)
> > are basically constants.
> > In the modify property page for the item in the "color rule
> > arguments" field, you can enter something like:
> >         A=chan1.SEVR, B=chan2.SEVR
> > Your color rule definition could be something like:
> >         $(A)    equals          MAJOR   and
> >         $(B)    less than       2       use     <A>B color>
> >         $(A)    equals          MINOR   and
> >         $(B)    equals          NONE    use     <A>B color>
> >         $(B)    equals          MAJOR   and
> >         $(A)    less than       2       use     <B>A color>
> >         $(B)    equals          MINOR   and
> >         $(A)    equals          NONE    use     <B>A color>
> > Note that the color is selected on a "first match" basis,
> > Also comparisons are done based upon the type of entry, i.e.
> > if a string is in the third column, the value of the first
> > column will be compared using a string compare and a numerical
> > compare will be done otherwise. It's awkward since you have to
> > define all possible comparisons separately.
> > Let me know if you have more questions.
> Thanks for your reply.
> I put the rule as below:
>          $(A).SEVR    equals          MAJOR   or
>          $(B).SEVR    equals          MAJROR  use     <A>B color>
>          $(A).SEVR    equals          MINOR   or
>          $(B).SEVR    equals          MINOR   use     <A>B color>
>          $(B).SEVR    equals          NO_ALARM   and
>          $(A).SEVR    equals          NO_ALARM use     <B>A color>
> and passed arguments to them:
> 	A=XXX:YYY:Z:chan1Alarm,B=XXX:YYY:Z:chan2Alarm
> But then when I activate the display dm "dies" (not possible to perform
> any action on the display, besides killing it from WM)
> Is there any limit concerning the total length of the arguments in the
> line ?
> Thanks for any comments.
> Regards,
> Marian
> Marian Zurek
> CERN/ECP-CO
Prev: Re: EDD/DM: Passing multiple arguments for color rule definition ? Janet Tvedt
Next: Re: EDD/DM: Passing multiple arguments for color rule definition ? Deb Kerstiens
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
