Please note that I gave some misinformation
about capfast output in my previous message.
Marty Kraimer
--- Begin Message ---
> If you convert to 3.13 the problem will either go away
> or else error messages identify the record and field that
> are causing problems.
I wholeheartedly agree.
> > I use CapFast to create the DB.
> I think this means that the database is in the .database format,
Nop.
CapFast under 3.12 uses a tool called e2sr (part of EPICS) to create short
report format data, then uses sf2db to generate db format (you can use dct
to generate binary format, too).
Under 3.13 e2sr is replaced by e2db that directly generates db format.
Cheerio,
Ralph
--- End Message ---
Re: Epics field names > 4 chars OK? Marty Kraimer
Re: copying of monitored data William Lupton
<1997>
2025
2026
167 serial ports Garrett D. Rinehart
What version of G++/GCC? Dave Reid
<1997>
2025
2026
