> HOWEVER,
> The biRecord.c support code is not incorrect because there get_enum_str,
> put_enum_str, get_enum_strs will ONLY get called if the field type
> in question is DBF_ENUM. The only such field in the biRecord is VAL.
> Many record support modules in base make this assumption.
Yes, but PV values in the CA server monitor queue will be ignored in favor
of the current value in the record if we leave the code as it is today.
Therefore, clients that monitor the .VAl field of a bo record as a
string will see the sequence of events "on off on" converted
to "on on on" if the events are spaced closely together in time.
Explanation:
This is because, when dbGetField() is called, the dbAddr structure
is pointing at the value on the CA monitor queue and not at the
.VAL field. The bo record's get_enum_str() routine ignores the
dbAddr structure passed in and always converts the VAL field
to a string (returning the current and not the historic value of
the .VAL field).
Jeff
- Re: copying of monitored data Marty Kraimer
Re: IOC hangs (scanOnce crashes) Chip Watson
Re: IOC hangs (scanOnce crashes) Ralph Lange
<1997>
2025
2026
<1997>
2025
2026
