1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC hangs (scanOnce crashes)
To: [email protected]
Date: Wed, 11 Jun 1997 09:31:09 -0500
Ralph Lange wrote:
> > Note that onceTask scans a record. Since records can be linked,
> > this means an arbitrary number of records can process. This means
> > an arbitrary set of record/device/driver support can be executed.
> Could I possibly be right if I assume that this might be valid for db links
> only, since ca links are executed by filling the event queue and waking up
> a ca event handler which then calls scanOnce() again starting another turn
> of this mechanism?
Yes this is correct.
An additional point.
For databases with many many database to ca links,
it is possible to fill the ring buffer even id onceTask
has not crashed. The ring buffer is set to 1000 entries.
It is possible to override this in the startup file via
scanOnceSetQueueSize(size)
This must appear before iocInit.
If however onceTask crashes, however, the ring buffer will ultimately
fill up.
Marty Kraimer
Re: IOC hangs (scanOnce crashes) Ralph Lange
Prev: Re: copying of monitored data Marty Kraimer
Next: Re: ACS Microstepper Drives Pete Jemian
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IOC hangs (scanOnce crashes) Ralph Lange
Next: Re: IOC hangs (scanOnce crashes) Chip Watson
