1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Fwd: ACS Microstepper Drives]
To: [email protected]
Date: Wed, 11 Jun 1997 12:19:37 +0000
[email protected] wrote:
> Kurt A. Goetze wrote:
> > Guy Jennings said:
> > > Just ran into a potential gotcha with the ACS SPD-3M Microstepper
> > motor
> > > drive module.=3DA0=3DA0 It is NOT a drop-in replacement for the SPD=
-6U
> > > drive!!!=3DA0=3DA0 The SPD-3M is a bipolar drive and needs differen=
t
> > connections
> > > when used with a 6-wire motor.
> > > Users beware!!!
> > I guess I would like to know more about how your motor is wired
> up.=3DA0
> > My
> > experience is that the SPD3M worked well as a drop-in replacement
> for
> > the
> > unipolar StepPak drive (using a 6 or 8 lead motor).
> > Kurt Goetze
> > APS/XFD/Beamline Controls
> =3DA0 We are using the connections in the APS 'standard' (I think!).
> For the SPD-6U:
> ELCO=3DA0=3DA0=3DA0 Signal=3DA0=3DA0=3DA0 SLO-SYN 6-lead
> A=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 1 Out=3DA0=3DA0=3DA0 Red
> B=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 2 Out=3DA0=3DA0=3DA0 Red/White
> C=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 3 Out=3DA0=3DA0=3DA0 Green
> D=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 4 Out=3DA0=3DA0=3DA0 Green/White
> E=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 1 Ret=3DA0=3DA0=3DA0 Black
> F=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 2 Ret=3DA0=3DA0=3DA0 Black
> H=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 3 Ret=3DA0=3DA0=3DA0 White
> J=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 4 Ret=3DA0=3DA0=3DA0 White
> This corresponds with Fig. 4.2 on page 17 of the ACS manual (Jan
> 1997).
> This does not match up with any of the connection diagrams on page 24
> or
> 25 of the
> ACS manual.
> I was able to succesfully move the motor with the following
> connections:
> A=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 1+=3DA0=3DA0=3DA0 Red
> B=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=
=3DA0=3DA0 NC
> C=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 3+=3DA0=3DA0=3DA0 Green/White
> D=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=
=3DA0=3DA0 NC
> E=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 1-=3DA0=3DA0=3DA0 Red/White
> F=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=
=3DA0=3DA0 NC
> H=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0 Ph 3-=3DA0=3DA0=3DA0 Green
> J=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=3DA0=
=3DA0=3DA0 NC
> This corresponds with Fig. 5.2 on page 25 of the ACS manual.
> Interestingly enough, we had previously tried the microstepper drives
> with an
> 8-lead motor and found no problems.
=A0 Sorry about the =3DA0 junk - something to do with Netscape...
The connection lists should be:
For the SPD-6U:
ELCO=A0=A0=A0 Signal=A0=A0=A0=A0 SLO-SYN 6-lead
A=A0=A0=A0=A0=A0=A0 Ph 1 Out=A0=A0 Red
B=A0=A0=A0=A0=A0=A0 Ph 2 Out=A0=A0 Red/White
C=A0=A0=A0=A0=A0=A0 Ph 3 Out=A0=A0 Green
D=A0=A0=A0=A0=A0=A0 Ph 4 Out=A0=A0 Green/White
E=A0=A0=A0=A0=A0=A0 Ph 1 Ret=A0=A0 Black
F=A0=A0=A0=A0=A0=A0 Ph 2 Ret=A0=A0 Black
H=A0=A0=A0=A0=A0=A0 Ph 3 Ret=A0=A0 White
J=A0=A0=A0=A0=A0=A0 Ph 4 Ret=A0=A0 White
For the SPD-3M
ELCO=A0=A0=A0 Signal=A0=A0=A0=A0 SLO-SYN 6-Lead
A=A0=A0=A0=A0=A0=A0 Ph 1+=A0=A0=A0=A0=A0 Red
B=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
C=A0=A0=A0=A0=A0=A0 Ph 3+=A0=A0=A0=A0=A0 Green/White
D=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
E=A0=A0=A0=A0=A0=A0 Ph 1-=A0=A0=A0=A0=A0 Red/White
F=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
H=A0=A0=A0=A0=A0=A0 Ph 3-=A0=A0=A0=A0=A0 Green
J=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
--- Begin Message ---
Subject: Re: ACS Microstepper Drives
Date: Wed, 11 Jun 1997 11:21:11 +0000
> motor
> > drive module.=A0=A0 It is NOT a drop-in replacement for the SPD-6U
> > drive!!!=A0=A0 The SPD-3M is a bipolar drive and needs different
> connections
> > Users beware!!!
> I guess I would like to know more about how your motor is wired up.=A0
> My
> experience is that the SPD3M worked well as a drop-in replacement for
> the
> Kurt Goetze
=A0 We are using the connections in the APS 'standard' (I think!).
For the SPD-6U:
ELCO=A0=A0=A0 Signal=A0=A0=A0 SLO-SYN 6-lead
A=A0=A0=A0=A0=A0=A0 Ph 1 Out=A0=A0=A0 Red
B=A0=A0=A0=A0=A0=A0 Ph 2 Out=A0=A0=A0 Red/White
C=A0=A0=A0=A0=A0=A0 Ph 3 Out=A0=A0=A0 Green
D=A0=A0=A0=A0=A0=A0 Ph 4 Out=A0=A0=A0 Green/White
E=A0=A0=A0=A0=A0=A0 Ph 1 Ret=A0=A0=A0 Black
F=A0=A0=A0=A0=A0=A0 Ph 2 Ret=A0=A0=A0 Black
H=A0=A0=A0=A0=A0=A0 Ph 3 Ret=A0=A0=A0 White
J=A0=A0=A0=A0=A0=A0 Ph 4 Ret=A0=A0=A0 White
This corresponds with Fig. 4.2 on page 17 of the ACS manual (Jan 1997).
This does not match up with any of the connection diagrams on page 24 or
25 of the
ACS manual.
I was able to succesfully move the motor with the following connections:
A=A0=A0=A0=A0=A0=A0=A0 Ph 1+=A0=A0=A0 Red
B=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
C=A0=A0=A0=A0=A0=A0=A0 Ph 3+=A0=A0=A0 Green/White
D=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
E=A0=A0=A0=A0=A0=A0=A0 Ph 1-=A0=A0=A0 Red/White
F=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
H=A0=A0=A0=A0=A0=A0=A0 Ph 3-=A0=A0=A0 Green
J=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
with an
--- End Message ---
Prev: Re: ACS Microstepper Drives jennings
Next: Re: ACS Microstepper Drives Kurt A. Goetze
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ACS Microstepper Drives Pete Jemian
Next: [no subject] Guy Jennings
