1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NFS vxWorks Access Rights
To: [email protected] (Andrew Johnson), [email protected] (EPICS Tech-Talk)
Date: Tue, 24 Jun 1997 14:42:08 +0200 (METDST)
> > Do you think this fits the FAQ explanation?
> I don't.  I wondered whether it might be that you're mounting a
> filesystem called '/' and '/something', but if you get reads working
> from the '/something' filesystem and you are sure these are through nfs
> and not via rsh or ftp then that's unlikely.
> What does nfsAuthUnixShow tell you about the uid/gid/gids of the target?
> Are they actually set to who you think they are?  If not, you might
> expect that behaviour if it's allowed read-only access to the directory.
I don't think the FAQ's explanation to be sufficient, either. I'm sure the
reads are via nfs (they work with rlogin disabled, we never use ftp
access - no password in the nvram).
nfsAuthUnixShow() tells me exactly what I want to see: Machine, uid and gid
match the ids on the host machine. For read access, the access bits of file
and directory work exactly as expected. Same is for write access using the
"real" (mounted) path. Only write access using the soft-linked path fails -
regardless of any mode bits (i.e. setting the directory to drwxrwxrwx
causes writes to fail).
Ralph
      __  Ralph Lange                         Email:       [email protected]
     /\ \                                     WWW: http://www.bessy.de/~lange
    /  \ \  BESSY II
   / /\ \ \  Berliner Elektronenspeicherring- Snail:                 BESSY II
  / / /\ \ \  Gesellschaft fuer Synchrotron-               Rudower Chaussee 5
 / / /__\_\ \  strahlung m.b.H.                       D-12489 Berlin, Germany
/ / /________\                                Phone:         +49 30 6392-4862
\/___________/ Control System Group           Fax:                ...   -4859
Re: NFS vxWorks Access Rights Andrew Johnson
Prev: Re: NFS vxWorks Access Rights Andrew Johnson
Next: Re: IOC hangs (still) Ralph Lange
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: calcAo Record BUG ! Ned Arnold
