1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SGL encoder in EPICS
To: [email protected]
Date: Tue, 8 Jul 1997 00:19:33 +0900
Dear All,
Does anyone use SGL encoder with CAMAC serial crate controller in
EPICS environment?
 We use camacLib.c from LANL in EPICS. We use Hytec CAMAC serial
highway driver and L-2 CAMAC Crate controller equipped with a SGL encoder.
On SGL encoder, you can patch 24 LAM signals to create SGL code ( 5 bits).
 SGL code is sent to the serial highway driver as a part of a demand message
when LAM is activated.
 camacLib.c, as I understand, uses SGL code as a slot number and clear LAM
on the slot where SGL code indicate.
 Since you can program SGL encoder as you like, the slot number of the
module in LAM status may diffrent from the number SGL code indicate, however.
So, I'm wondering if anyone in EPICS collaboration other than us uses a SGL
encoder and how they maps SGL code to the slot number which is in LAM status.
Thank you,
Noboru
KEK, KEKB control group
JAPAN
Prev: Re: Bad CALC record kills IOC Marty Kraimer
Next: CPU speed on mv162/167 Ralph Lange
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Building extensions with beta10 Bakul Banerjee
Next: RE: SGL encoder in EPICS Eric Bjorklund, NPSM
