1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: InitHooks
To: "'Benjamin Franksen'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 14 Jul 1997 13:31:30 -0600
Ben,
> I propose a (minor) change to the next EPICS release. Current problems
> with the new lanGpib driver suggest that an entry in the InitHooks
> function should be made in that calls the driver at some later point
> during IOC init. So far so good. But in our control system there are
> already some standard entries in this InitHooks function. And InitHooks
> only exists once.
Driver support is called once before and after database initialization Is this
sufficient for your needs?
Your request appears to be reasonable with the exception that
the example code should handle the situation where malloc()
fails (and therefore registerInitHook() should return status).
Marty Kraimer is maintaining the source code involved.
Jeff
______________________________________________________
Jeffrey O. Hill           Internet     [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Prev: Building EPICS on HP_UX 10.2 Dave Reid
Next: Re: InitHooks Marty Kraimer
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: InitHooks Marty Kraimer
Next: Re: InitHooks saa
