1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: InitHooks
To: [email protected]
Date: Tue, 15 Jul 1997 11:23:45 -0500
[email protected] wrote:
> Ben Franksen wrote:
> > (s)he wants to have a simple installation procedure like
> >"place a call 'register...' in your startup file" and _not_ "You also
> >have to copy your initHooks.c to your application directory, patch it in
> >the following (detailed explanation here, where to put the code)
> This procedure with initHooks.c is exactly something I have to do for
> warm restart (bumpless reboot).  I add in the calls to restore data at
> the proper places in initHooks.  Other people must be doing a something
> similar.  If it is decided not to add in some sort of registration as
> Ben suggests which could also be used for warm restart, then it'd be
> good to have this initHooks procedure added to the "EPICS IOC Application
> Building and Source Release Control" (EPICS Release 3.13.0.beta7).  I'll
> help define this procedure if need be.
> Stephanie Allison
> [email protected]
I agree that we should have the existing initHooks replaced
by Ben's suggested version. I dont think there are any compatibility
problems since iocInit does a symFindByName to locate initHooks.
Thus if existing application supply their own initHooks.c ther should
still work.
Marty Kraimer
Re: InitHooks saa
Prev: Re: InitHooks saa
Next: IOC's for new project Hammonds, John
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Building EPICS on HP_UX 10.2 Noboru Yamamoto
