[email protected] said:
> > Is anyone aware of a use of ULONG to hold a number larger than 2^31
> > which would fail if the value were contained in a 32 bit int?
> I think I'll stand up for the "less sophisticated" EPICS Application
> Developer (of which there are many !) and respond "I don't know what
> you mean by a ULONG. Does that mean my system will break ? I got all
> my stuff from Epics_Genius_such_and_such. Should I be worried ? ".
OK, a bit of education and editorializing:
A ULONG is a 32 bit integer which is always positive. I.e. the most
significant
bit does not hold the sign, but instead holds 2^31 (=~ 2 x 10^9). Anyone
out there using numbers that large? Fields in EPICS records effected are:
1) fields specifying number of elements & offsets
(array records, waveform, subArray, etc.)
no problem here, as no one works with array of length 2,000,000,000.
2) fields holding raw values & masks for bi, bo, mbbi*, mbbo*, pal records
IMHO no problem since these do not represent integers anyway, only
bits
3) pulse counter record -- I can believe that an application may eventually
count more than 2^31 pulses, so care should be taken here, perhaps by
converting this field type to double to prevent overflows. In this
case no channel access client would be effected since they are fetching
this data as a double already.
(Info gleaned from *.ascii files).
The use of ULONG instead of the C type int on 32 bit machines is partly a
purist
approach of declaring numbers which you know to be positive (lengths of arrays)
to be of a datatype which by definition is positive. However, having an array
of length
2^32 (=gigabytes) will likely cause as much trouble as an array of length
minus 2^31
for any control system application.
Chip
- Re: change in promotion of types from database to channel access Ned Arnold
EPICS fd registration problem Firmin Oliveira
<1997>
2025
2026
database check in R3.13.0 Rolf Keitel
<1997>
2025
2026
