X-Sun-Data-Type: text
X-Sun-Data-Description: text
X-Sun-Data-Name: text
X-Sun-Charset: us-ascii
X-Sun-Content-Lines: 14
Jeffrey,
I attach the latest release, which should be identical to Andrew's
EXCEPT that I believe it has device support for extra record types.
I have attached the README separately (it's in the tar file too).
I regret that this is probably not in the main R3.13 release and has
not, as far as I know, been tested with R3.13. Also, the Makefiles will
need some massaging.
William
PS, Is this file acceptable as a submission for inclusion in the official
release? If not, what more is required?
X-Sun-Data-Type: default
X-Sun-Data-Name: symb-2-11.tar.gz
X-Sun-Encoding-Info: uuencode
X-Sun-Content-Lines: 228
begin 600 symb-2-11.tar.gz
M'XL("(F;*30 W-Y;6(N=&%R .Q=>W/;MK+OO^*<#X$J:2PYMJRW8[G)/8H?
MB4X5R6,ZSO3F9#R4"-EL*)(E*3N^G7SWN[L *% OR[&=M(DP&4L"P,5B=['8
MWX)DHNMA;^NGARW%8K6X7:O!9[%8JF[39[56I4]9?BK6JZ5RI52K;9>AOE0I
M%BL_U1Z8+RJC*+9"&/+*'06Q[\WMYWA1'"Z@0].H%N6DZO?/Z,.4"/5?L(+
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MK-S2J<3IYC[&*+,OQ,SB5++13:<:M=Y3&<>D;3K+F#1-OSMLXB80$!=*2N@
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MA@F?\RBT3!.&/&NVF\=OC*-C\)7M[COCL-WY;<X5^ @V^_?$]-_7/L#%!WO
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M'RZERJ9MLVPQN\&RI?)V 59#H91%NFT?/;[email protected]:*QH_(@8L>A?@B16P8
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MANS796[ZI%$=W#D'SAM(L*G75"V^Z^3UOXI$>G&[[email protected]/R\=D9.;A6"4B%
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M_=]MY<4M/*+SA%\0OA.=1_5*C+PZ(\6>^R3T,A.=_[W:EQY#6RVEC93S/WJ
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MF^[F8QCQ041X4=_%F8)0;/$ $F^1#MP8X(%/=(S4;#>^PD-3X,0G1ZW9-WO
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9.FXI;GTOR*G/))-,,FF*]#_L^2L: #0! /:A
end
X-Sun-Data-Type: readme-file
X-Sun-Data-Name: README
X-Sun-Content-Lines: 52
README file for dev/symb directory
This directory contains all files necessary to build and test a version
of EPICS vxWorks global variable device support which uses the INST_IO
string as the variable name specification rather than deriving the name
from the record name.
In addition to specifying a variable name, a leading "*" operator indicates
that the variable is a pointer and a trailing "[nnnn]" indicates that an
element of an array should be accessed.
Refer to the header comments of devSymbFind.c for full details.
The following files are in the release:
README This file
Makefile UAE Makefile
Makefile.Vx UAE vxWorks Makefile
devAiSymb.c Modified versions of standard EPICS
devAoSymb.c vxWorks global variable device support
devBiSymb.c
devBoSymb.c
devLiSymb.c
devLoSymb.c
devMbbiSymb.c
devMbbiSymbRaw.c
devMbboSymb.c
devMbboSymbRaw.c
devSiSymb.c
devSoSymb.c
devWfSymb.c
devSymb.h Definitions
devSymbFind.c New module containing parsing code
(includes conditionally compiled test routine)
devSymbTest.c Defines globals and a routine for test
devSup.ascii New INST_IO entries for the above six records
symb.sr Test database (works with devSymbTest.c)
symbStartup.vws Test vxWorks startup script
24-Sep-97, William Lupton ([email protected]), CVS tag: symb-2-11
first release
- Re: Enhanced vxWorks Variable Support Marty Kraimer
Enhanced vxWorks Variable Support Jeffrey Mcdonald
<1997>
2025
2026
<1997>
2025
2026
