1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Enhanced vxWorks Variable Support
To: "'Jeffrey Mcdonald'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 25 Sep 1997 10:57:35 -0600
Hello all,
> 	I want to read out a VME memory board using a waveform record.
> The VME memory board is located at 0x006c0000.  I want to readout 100
> unsigned long elements beginning at the memory board's base location.
> 	In a response from Rozelle Wright, I found out that this problem
> has been solved by Andrew Johnson.  Below is a message from Andrew Johnson
> regarding the enhanced vxWorks variable support package.  Does there exist
> a version for R3.13 and has it been tested with R3.13?
Some advantages of taking the time to write custom device support for
your waveform device...
o vxMemProbe is used during initialization  (no bus error when card not present)
o sysBusToLocalAddr() or devLib style address mapping (database is CPU model
	independent)
o database addresses device by card number (easy to add additional cards and
	rearrange the address map without changing the database)
o synchronize the database with updates to the waveform (avoid fetching
	part of the waveform from one data take and part from another)
o diagnostics for this card show up in dbior() (IO reports)
o database can enter alarm state when the card is sick
Jeff
______________________________________________________
Jeffrey O. Hill                      Internet     [email protected]
LANL MS H820                    Voice         505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Prev: Archiving & save/restore update Bob Dalesio
Next: Re: Enhanced vxWorks Variable Support William Lupton
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Enhanced vxWorks Variable Support Marty Kraimer
