I'm writing device support for the VMIC 2120. This is a 64 bit digital
output device. Its data address map is as follows:
Relative Address mnemonic function
xxx0 DR0 data register 0 (bits 56 - 63)
xxx1 DR1 data register 1 (bits 48 - 55)
xxx2 DR2 data register 2 (bits 40 - 47)
xxx3 DR3 data register 3 (bits 32 - 39)
xxx4 DR4 data register 4 (bits 24 - 31)
xxx5 DR5 data register 5 (bits 16 - 23)
xxx6 DR6 data register 6 (bits 8 - 15)
xxx7 DR7 data register 7 (bits 0 - 7)
For binary output support I use a 32 bit write to DR0 or DR4 in the
following
manner:
if (signal > 31) use DR0
else use DR4
A problem arises with mbbo support. At the record support level
the value field is set to zero for signals > 31.
I've looked at several options:
1) Regard the module as two separate 32-bit devices with different base
addresses
2) Use PARAM as an address offset (eg #C0 S0 @0x0004 or #C0 S0 @0x0000)
3) bypass the VAL field and access the the state masks directly
I'm sure this problem will crop up with other devices.
Anyone have any suggestions
Graham.
| Graham Waters, Control System Eng Internet: [email protected]
| TRIUMF --- University of British Columbia, phone: (604)-222-1047 |
| Vancouver, BC, Canada Fax: (604)-222-7307
| http://sunset.triumf.ca/homepage/graham01.html
Re: Enhanced vxWorks Variable Support William Lupton
NV Ram use under EPICS Holger Jones
<1997>
2025
2026
Archiving & save/restore update Bob Dalesio
<1997>
2025
2026
