1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Generic Record Types
To: [email protected]
Cc: [email protected]
Date: Fri, 26 Sep 97 16:13:48 MDT
> From [email protected] Fri Sep 26 15:57:01 1997
> Return-Path: <[email protected]>
> Date: Fri, 26 Sep 1997 16:56:14 -0500 (CDT)
> Subject: Generic Record Types
> Mime-Version: 1.0
> Content-Type> : > TEXT/PLAIN> ; > charset=US-ASCII>
> Content-Transfer-Encoding: 7BIT
> Content-Length: 751
> X-Lines: 21
> Hello,
>         There are several generic records that Mark Rivers has written
> for EPICS R3.12 that would be very useful in R3.13.  In particular, the
> generic VME record and the generic GPIB record would be very useful for
> some of my work.
>         Does anyone have a tool for converting .ascii files into
> the required .dbd files or has someone already converted these files into
> the format required to use these generic record types in R3.13?  (It may
> not be as simple as just converting .ascii files into .dbd files.)
>                         Jeff
> _____________________________________________________
> Jeffrey McDonald, Florida State   [email protected]
> FNAL MS 352			  phone   630-840-8301
> Batavia, IL 60510                 fax     630-840-8886
Look on page 6 and 7 of the EPICS Release BaseR31.3.0.beta11 release notes.
This describes routines starting with sdr* that
exist in the base/bin/<host> directory
for epics 313 releases.  You must however, have a default.dctsdr
file from 312 to do the conversion.  Someone may have done the conversions
already if you list which ones you need.  Also there are tools available
on thoth.atdiv.lanl.gov /epics/BETA_4_DB2CAPSYM.tar.gz
and /epics/DBST_1_0.tar. which can be used to create capfast symbols
and edb.def definitions for capfast respectively. But if someone already
has made the symbols it is easier.
Hope this helps,
Rozelle
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs LANSCE-8  FAX (505) 665-5107      |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
Prev: Generic Record Types Jeffrey Mcdonald
Next: Re: Generic Record Types Tim Mooney
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Generic Record Types Benjamin Franksen
