1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: FYI: Survey of Telescope Control Systems
To: [email protected]
Date: Tue, 30 Sep 1997 07:49:45 -1000
Aloha,
	Recently I have begun a survey of current trends in the design
of telescope control systems within the Mauna Kea community. My
primary concern has been with the actual telescope control software (that is -
machine rather than detector control).
	It could be interesting to compare architectures across the
experimental physics (and astronomy) controls community.
	The current survey results can be found at:
http://www.cfht.hawaii.edu/~mcgehee/survey/index.html
	A copy of the survey questions follow - some of the phrasing
is telescope-specific.
Peregrine
I. Context
     What are the principal components (including a TCS) of your
facility-wide software and control system?
II. Interfaces
     What are the software interfaces between the TCS and the other
principal components?
III. User Interfaces
     Does the TCS provide a direct interface to the operator? If so, how?
IV. Data Stores
     Does the TCS provide access to any data stores such as
configuration and object catalogs? If so, how?
V. Sequencing
     Does the TCS provide for command sequencing at a high-level?
VI. Command Support
     How does your system support completion of system demands such as
slewing to a new target? Do these commands act on a collection of
virtual telescopes? If so, what virtual telescopes are defined?
VII. Astrometrics
     Under what environment do your astrometric calculations run?
VIII. Pointing Models
     How are your pointing models (especially for the mount)
implemented? Under what environment do they run?
IX. Subsystem Control
     Under what environment do your hardware-specific subsystems
(like the mount controller) run?
X. Resources
     What are the resources (in FTEs) allocated for maintenance and
upgrade of the software and control systems associated with control of
the telescope?
Prev: Re: Generic Record Types Tim Mooney
Next: (no subject) Frederic MICHAUD
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
