1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PB with the time stamp
To: "'Frederic MICHAUD'" <[email protected]>, EPICS talk <[email protected]>
Date: Wed, 1 Oct 1997 09:46:34 -0600
Fred,
You need to set the environment variable "EPICS_TS_MIN_WEST" on your UNIX host so that
the time stamps will be correctly converted to the local time zone. The details are in the
configuration section of the CA reference manual which is on the web at Los Alamos.
Jeff
On Wednesday, October 01, 1997 5:09 AM, Frederic MICHAUD [SMTP:[email protected]] wrote:
> Hi
> I have a problem with the time stamp of the archiver:
> Here is my configuration
> TSconfigure (1,0,50,0,0,0,1)
> TSreport
> Soft timing master
> Master timing IOC alive
> Time protocol sync with unix
> Clock Rate in Hertz = 60
> Sync Rate in Seconds = 10
> Master communications port = 18323
> Slave communications port = 18322
> Total events supported = 1
> Request Time Out = 250 milliseconds
> the date and time are goods on vxwork, and when I use the archiver, I
> have the good date but the time stamps are wrongs.
> Regards,
> 		Fred
> _________________________________________________
> Frederic MICHAUD
> CERN	 : CH-1211 Geneve 23 - Switzerland
> Division : ECP-CO
> phone    : (+41) 22 767 65 54
> 		        33 59
> E-mail   : [email protected]
Prev: PB with the time stamp Frederic MICHAUD
Next: Serial comms solution Josep A. Perlas
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
