1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem w/gdct and epics 3.13
To: [email protected]
Date: Thu, 16 Oct 1997 17:09:30 -0500
I recently built epics 3.13beta11 for solaris and am trying to get going
with gdct313, which I obtained prebuilt from the solaris platform
developers site.
However, the first step seems to be a doozy. When I start up gdct313 in
<epics base>/dbd, I get the following error messages:
Using dbd include path /usr/local/epics/3.13/base/dbd
Error "menu not found"  Last token ")"
input line:             menu(menuScan)
   in: path "/usr/local/epics/3.13/base/dbd"  file dbCommon.dbd line 22
   in: file /usr/local/epics/3.13/base/dbd/dbCommonRecord.dbd line 2
Error "syntax error"  Last token ""
db_parse returned -1
Read failed: dbd file /usr/local/epics/3.13/base/dbd/dbCommonRecord.dbd
Read dbd file: /usr/local/epics/3.13/base/dbd/menuGlobal.dbd
Read dbd file: /usr/local/epics/3.13/base/dbd/base.dbd
Error "syntax error"  Last token "field"
input line:     field(NAME,DBF_STRING) {
   in: file /usr/local/epics/3.13/base/dbd/dbCommon.dbd line 1
Read failed: dbd file /usr/local/epics/3.13/base/dbd/dbCommon.dbd
After this I get normal looking reports that it has read the rest of the
.dbd files. I would appreciate a hint as to what is going on here.
 Dale L. Brewe
 PNC-CAT/U. of Washington
  ph: 630 252 0582
 fax: 630 252 0580
 Address:
 APS/Argonne National Laboratory
 Bldg 435E sector 20
 9700 S. Cass Ave.
 Argonne, IL 60439
Re: problem w/gdct and epics 3.13 Marty Kraimer
Prev: edd/dm 2.2 Bill Brown
Next: Re: problem w/gdct and epics 3.13 Marty Kraimer
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
