1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.13.beta11 & Tornado 1.0.1
To: [email protected]
Date: Tue, 21 Oct 1997 08:06:02 -0500
Gabor Csuka wrote:
> Hi All,
> I play with the configuration of R3.13.beta11 & Tornado 1.0.1
> After some modification (base/config/CONFIG*) I have the following problem:
> useing gmake install.mv167 I got:
> [krykSunB] ~/EpicsR13/base/src/libCom/O.mv167 % /usr/wind/host/sun4-solaris2/bin/cc68k -B/usr/wind/host/sun4-solaris2/lib/gcc-lib/ -nostdinc -DCPU=MC68040 -m68040 -DCPU_FAMILY=MC680X0 -O -Wall -pedantic -ansi -fvolatile -fno-builtin -I. -I.. -I../../../src/include/os/vxWorks -I../../../include -I../../../include -I../../../include/os/vxWorks -I/usr/wind/target/h -DvxWorks -DV5_vxWorks -c ../calcPerform.c -o calcPerform.o
> as: error: unknown option '6'
> as: error: unknown option '8'
> as: error: unknown option '0'
> as: error: unknown option '4'
> usage: as [-V] [-Q{y,n}] [-f[O][if]#] [-q] [-s]
>           [-S] [-K {pic,PIC}] [-o objfile] [-L] [-T]
>           [-P [[-Ipath] [-Dname] [-Dname=def] [-Uname]]...]
>           [-m [-Ym,path]] [-n] [-xF] [-xarch=v7] [-xarch=v8] [-xarch=v8a] [-xarch=v8plus] [-xarch=v8plusa] file.s...
> It is comeing, while the 'as' is /usr/ccs/bin/as, if I have (e.g.) a link
> as -> /usr/wind/host/sun4-solaris2/bin/as68k, than it is fine.
> But if I want to use pc468 as a target the as must be /usr/wind/host/sun4-solaris2/bin/as386.
> The question : How can I tell the gmake/cc68k to use /usr/wind/host/sun4-solaris2/bin/as68k as 'as' ? Or any other solution ? Or I'm dumm ?
> Regards,
> Gabor Csuka
> DESY, Germany
The next release of base will support both both vxWorks 5.2 and vxWorks
5.3, i.e.
tornado. The diffs from beta11 for CONFIG_COMMON and CONFIG_SITE are:
Index: CONFIG_COMMON
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/config/CONFIG_COMMON,v
retrieving revision 1.9
diff -r1.9 CONFIG_COMMON
2c2
< #  $Id: CONFIG_COMMON,v 1.9 1997/06/25 06:37:23 jhill Exp $
> #  $Id: CONFIG_COMMON,v 1.10 1997/10/10 13:52:47 mrk Exp $
61a62,68
> #VX_IS_TORNADO = 1
> ifdef VX_IS_TORNADO
> VX_CONFIG_DIR = $(VX_DIR)/target/config
> VX_INCLUDE = $(VX_DIR)/target/h
> VX_GNU_BIN = $(VX_GNU)/bin
> VX_GNU_LIB = $(VX_GNU)/lib
> else
65a73
> endif
Index: CONFIG_SITE
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/config/CONFIG_SITE,v
retrieving revision 1.12
retrieving revision 1.15
diff -r1.12 -r1.15
2c2
< #  $Id: CONFIG_SITE,v 1.12 1997/06/25 14:09:40 jba Exp $
> #  $Id: CONFIG_SITE,v 1.15 1997/10/10 13:52:48 mrk Exp $
42a43
48a50,57
> # The definitions VX_DIR, VX_GNU, GNU_DIR and GNU_LIB
> # are used for the Vx build only. These defintions
> # can be overridden for specific host architectures
> # by creating a CONFIG_SITE.Vx.68k.<host_arch> file
> # with the override definitions.
53c62
< VX_DIR=/usr/local/vw/vxV52p1/vw
> #VX_DIR=c:/Tornado/target
55,56c64,70
< #  Gnu directory for gcc
< #VX_GNU = $(VX_GNU)
> ifdef VX_IS_TORNADO
> VX_DIR = /usr/local/vw/tornado101
> VX_GNU = $(VX_DIR)/host/$(WIND_HOST_TYPE)
> WIND_BASE = $(VX_DIR)
> WIND_HOST_TYPE = sun4-solaris2
> else
57a72
> endif
In order to switch from 5.2 amd 5.3 it will only be necessary
to remove the comment character from
#VX_IS_TORNADO = 1
Marty Kraimer
R3.13.beta11 & Tornado 1.0.1 Gabor Csuka
Prev: Re: ai record support has an error Marty Kraimer
Next: Bug in longinRecord Ralph Lange
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: R3.13.beta11 & Tornado 1.0.1 Ralph Lange
