1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: archiving with sdds
To: EPICS talk <[email protected]>
Date: Mon, 27 Oct 1997 19:16:17 +0100
I'm using sdds to archive  data coming from EPICS records.
I want to write PV readback values to a file using the sddsmonitor
function, but I also want that the monitored PV values are saved
only when they change more than a delta (ie apply option like glitch to
all the monitored PV
and not only one of them).
For the moment, the only solution I've found is to launch several
sddsmonitor with the same input file 'glitched' on different PV and
writting in the same output file. Is there simple meaning to do that.
Another question : is it possible to archive string data type (state
name in this case) in a sdds file. these datas come from a stringin
record.
Thanks in advance,
Regard,
                                                            Fred
_________________________________________________
Frederic MICHAUD
CERN    : CH-1211 Geneve 23 - Switzerland
Division: ECP-CO
Phone   : Office (+41) 22 767 33 59
        : Home   (+33) 04 50 40 71 19
FAX     : Office (+41) 22 767 74 10
E-mail  : [email protected]
Prev: Re: Serial comms solution Peregrine McGehee
Next: cadef.h Nick Rees
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: List of Record Support not in base. Steve Lewis
