Just a comment/question on a detail - sorry if this sounds too obvious ...
> [... becon time / reboot ...]
> the reconnect problem for IOCs that take minutes to boot (we're still
> on beta4).
I don't see why the beta4-to-beta11 step would increase an IOCs boot up
speed - do your IOCs have NFS access to their boot server?
We once had a problem where one of the "larger" IOCs took about 10 minutes
to boot. It turned out that we forgot to have this IOC listed in the
/etc/exports file of the boot host so that vxWorks used the fallback method
(remsh) to load the database. If you use templates, the .db file gets
opened once per instantiation (this leads to an overhead of ~1 second per
instance!!).
We're also running beta4 on all our crates. The statistics for our largest
IOC are
CPU: MV162-042 (20 MHz, 8 MB)
OS: vxWorks 5.2
EPICS: 3.13.0.beta4
Database: 510 template instances create 1726 soft and 514 hardware records
(sums up to 2240 records; 6.5 MB of allocated memory)
Seq: 3 state sets
Load: ~50% (when idle)
Boot up: reboot until iocInit 1:25 min
iocInit 0:55 min
(Note: iocInit takes long because it has to set up two intelligent field
bus cards where each data object has to be configured separately.)
(BTW: This was the IOC with the 10 min boot up time using remsh access.)
Hope this helps (or doesn't hurt, at least) ...
Ralph
- beacon period and ioc boot time saa
RE: beacon period and ioc boot time Jeff Hill
IOC master/slave synchronization Ron Chestnut
<1997>
2025
2026
<1997>
2025
2026
