1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Allen Bradley 6008-SV scanner : Bad prom
To: [email protected]
Cc: [email protected]
Date: Fri, 19 Dec 1997 07:41:51 -0600
We have received new 6008-SV modules that failed.
The problem was identified as a firmware bug.
The problem appears to be with the prom located nearest to the VME
connector. I can not be sure which prom versions are bad. However I
suspect any V2.x version. We replaced the V2.x prom with a copy we made
of a V1.x prom and it worked just fine.
The symptoms I saw were queue overflow messages and dbior showed many
command errors and a maximum of about 10 block transfers per second.
This was on a system that does >40 block transfers per second.
Marty Kraimer
Prev: A Problem Initializing drvGpib with the NI-1014 Module J. Frederick Bartlett ([email protected])
Next: Allen Bradley EPICS support Marty Kraimer
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
