1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS r3.13 field DESC length
To: [email protected]
Date: Thu, 08 Jan 1998 14:05:18 -0600
William Lupton wrote:
> > Note also that the warning message is telling the application engineer
> > that he/she has given a value that will not appear as specified in the
> > database. It really is a database configuration error.
> I had assumed that the default DESC strings were somehow in base, but in
> fact I think this is not the case: the defaults are in the Capfast symbols.
> Perhaps we should at least ensure that none of the default DESC strings in
> the symbols exceeds the limit and triggers the warning?
I will let all of you Capfast folks figure this out.
> Finally, I can't help following Andy's lead and asking why there is no
> record field that indicates the record type. I believe that this could
> often be useful. What about RTYP?
I think Andy was proposing something different. He was asking for a
field that gives the version of the record. He said
        field(VERS,DBF_DOUBLE) {
                prompt("Version Number")
                promptgroup(GUI_DISPLAY)
                special(SPC_NOMOD)
                interest(1)
If this is used then the record support module is responsible for
setting the version value.
In this case we could put this new field in dbCommon (yet another
dbCommon field???)
This would mean that all existing record support would have to be
modified to set the version number.
Now if this is changed to
                special(SPC_NOMOD)
                interest(1)
                initial(<version>)
The record developer changes <version> whenever he/she modifies the
record support.
Thus the version will be available automatically. If this is done we
can't put the field in dbCommon.
With regards to accessing the record type via channel access, Matthais
Clausen asked for this a long time ago. I have it on my 3.13 TODO list.
Your proposal is one way to handle the problem (yet another dbCommon
field???). It does, however, require that the client take a channel
name, strip off the field, append "RTYP", and do a search and get. Maybe
this is an OK interim solution. Another possibility is too see if some
changes to dbAccess and ca can make it possible to just ask CA directly
for the record type just like you can now ask for native type, native
count, etc.
Ultimately we should allow full dynamic discovery of record type, field
names, field types. This will NOT happen until at least CA V4.
By the way this is the next item on my epics 3.13 TODO list. Thus
comments are welcome. Maybe William's suggestion is what we should do
for 3.13. It is certainly simple. The static database access library
could fill in the name. Thus no other code needs to be modified.
Marty Kraimer
Re: EPICS r3.13 field DESC length William Lupton
Prev: Re: EPICS r3.13 field DESC length William Lupton
Next: Re: EPICS r3.13 field DESC length William Lupton
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
