1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: what is the criterion for whether .VAL has PP attribute TRUE?
To: [email protected]
Date: Tue, 20 Jan 1998 16:57:02 -1000
Dear all,
I note that some records have the PP attribute set on their .VAL field
and some don't. Under R3.12 those common ones that _don't_ are:
  calc, event, histogram, pal, scan, sel, switch, wait
What is the rationale for this? I often attach PP OUTLINKs to .SLNK
ports (.VAL fields) and use them as a combined data and control flow.
This works just fine to output records, where you can put them in
closed_loop mode if you want to fetch your own value for .VAL. However I
just tracked down a problem where such an OUTLINK was attached to a
passive calc and the effect, of course, was to put to the .VAL field
(which posted a monitor) and _not_ to process the record, which was
surprising at first.
  William
Re: what is the criterion for whether .VAL has PP attribute TRUE? Andy Foster
Prev: Galil dmc-1300 support Jeffrey Mcdonald
Next: Re: what is the criterion for whether .VAL has PP attribute TRUE? Andy Foster
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
