1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: new record support
To: [email protected], [email protected]
Date: Thu, 22 Jan 1998 11:17:40 -0600
> From [email protected] Thu Jan 22 11:10 CST 1998
> Subject: new record support
> MIME-version: 1.0
> Content-transfer-encoding: 7BIT
> 	I would prefer to have a single record for the download.  However,
> I'm not sure how this fits into epics.  I would like the users to perform
> caputs for each of the parameters.  After all of the parameters have been
> filled (each would have a field in the record), the user performs
> another caput to indicate that all of the parameters
> have been filled and the record can process by writing to the
> proper vme addresses.   This is where I'm not sure how this fits into
> epics.  I only want the record to process (write to port card) once, even
> while I am performing caputs -- which as I understand causes the record to
> process.
> 	I doubt that this is the first time a problem such as this has
> been encountered and I would appreciate any advise as to how to best
> approach this problem.
Just a thought: You'll have your own processing routine to go along with your
new record type anyway. Therefore, you can have your processing routine be smart
enough to only actually talk to the hardware when the "ready to go" field has
been filled in. Any other processing would just update the necessary fields in
the record.
-- Garrett Rinehart
   Intense Pulsed Neutron Source
   Argonne National Laboratory
Prev: new record support Jeffrey Mcdonald
Next: Re: about GPIB interface Bill Brown
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: new record support Carl Lionberger
Next: Re: new record support Ned Arnold
