1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Running CA Server on VMS - Data Conversion Problem
Date: Tue, 3 Feb 1998 09:39:29 -0700
> I added the CONVERSION_REQUIRED define (along with MULTINET and
> "caNetAddrSock") to my cxx command and the example server now works
> great and data looks good.  And of course, /float=d_float just like
> for the client.  This solution can be made permanent as far as I'm
> concerned.  Thanks,
Yes, sorry I had a temporary bit of amnesia, and you are correct. In fact gdd
does not currently handle floating point conversion, but the CA server does  if
CONVERSION_REQUIRED is defined because it will then use the host format
to network format conversion code that is built into the CA client library. This
change was added when we were porting to the PC environment to solve
endian problems, and so I didn't immediately leap to the conclusion that the VMS
floating point conversion problems had been solved.
Jeff
Prev: Re: Running CA Server on VMS - Data Conversion Problem saa
Next: Re: proposed RTYP field Marty Kraimer
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: alh group reset mask question William Lupton
