1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Xycom 566 waveforms
To: [email protected]
Cc: [email protected]
Date: Wed, 11 Feb 1998 13:11:44 -0600
> Garrett D. Rinehart wrote:
> > I'm trying to read all 32 channels of a Xycom 566 into a
> > waveform record, but I cannot get it to work.
> > I have tested the board with AI records and it works fine.
> > When I remove the AI's and put in a WF, it just looks at me
> > stupidly.
Andrew wrote:
> If you look at the drvXy566.c file you'll see that ai and wf support
> effectively use two separate drivers, and I think they use different
> base addresses for their cards.
Andrew is correct. My "very old notes" indicate the following ...
Xycomm 566 Mode      Register Address (A16)      Memory Address (A24)
Single Ended		0x6000			0x000000
Differential		0x7000			0x040000
Differential Latched    0xE000			0x0C0000
Waveform Mode		0x9000			0x080000
These values, of course, can be modified using module_types.c
	Ned
Prev: gdct313 - stepper-motor record problem. Bill Brown
Next: stepper-motor vs. motor record Janet Tvedt
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Xycom 566 waveforms Bob Dalesio
Next: gdct313 - stepper-motor record problem. Bill Brown
