1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gdct313 - stepper-motor record problem.
To: Bill Brown <[email protected]>
Cc: [email protected]
Date: Thu, 12 Feb 1998 07:05:37 -0700 (MST)
The stepper motor record was intended to have readback from either
nothing entered - it's own position - this is totally open loop
.EPOS - the encoder - need to know the initial position so see IALG
some other position readback from an analog input.
We've used them before with the EPOS as the feedback.
	Bob
On Wed, 11 Feb 1998, Bill Brown wrote:
> I'm experimenting with GDCT313 for a project that's starting to happen,
> and I've run into a problem.  Local people haven't done this particular
> thing before with this version, so it seems reasonable to toss it out
> for general comment.
> We're using the OMS controller for stepper-motor drives.  Several of these
> drives will have encoder feedback.
> I create the picture for the record, "export" the RDBL and EPOS fields, and
> link the output of EPOS to RDBL.  GDCT313 does this with no complaint.
> The database which gets generated does not reflect this, however:
> 	grecord(steppermotor,"Bl04:theFirstMotor") {
>         field(OUT,"#C0 S0 @")
>         field(RDBL,"Bl04:theFirstMotor.VAL PP MS")
>         field(MODE,"Position")
>         field(CMOD,"Position")
> Note the RDBL is linked to the VAL field instead of the RDBL field.
> Anybody have a clue as to why this is happening?  I _think_ I've got the
> base* files properly configured, and the cpu boots without complaint.  It
> even reads the .dbd and .db files without complaint.
> I've got some wiring to do before I can "give it the smoke test," so it seems
> reasonable to ask for suggestions now, as it seems likely that the generated
> database isn't gonna do what I need it to do.
> Any and all suggestions greatly appreciated.
> -bill
gdct313 - stepper-motor record problem. Bill Brown
Prev: Re: Xycom 566 waveforms Bob Dalesio
Next: seq records/constant links Jeffrey Mcdonald
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: gdct313 - stepper-motor record problem. Bill Brown
Next: stepper-motor vs. motor record Janet Tvedt
