1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SNC crashes
To: EPICS Techtalk <[email protected]>
Date: Tue, 10 Mar 1998 22:38:48 +0100
Hello SNC-Experts,
I have a problem with the State Notation Compiler. The snc crashes with
a 'Bus error (core dumped)' message whenever I try to compile my SNL
program of which I attached a 'maximally downsized' version (test.st).
The funny point is, that one can eliminate virtually any declaration
from it and the SNL compiler will translate it without any error. I
think the error has to do with some overflowing internal array but I
wouldn't bet on it...
    Ben
The Notorious Neb Nesknarf
BESSY II
Berliner Elektronenspeicherring-                phone: +49 30 6392-4865
Gesellschaft fuer Synchrotronstrahlung            fax: +49 30 6392-4859
Rudower Chaussee 5                         email: [email protected]
D-12489 Berlin                       web: http://www.bessy.de/~franksen
HOME: Benjamin Franksen, Fichtestr. 19a, D-10967 Berlin, +49(30)6913756
program test
#define NPORTS 51
#define NLINES 21
/* process variables tabEdit.db */
double tabElem[NPORTS];
assign tabElem to {""};
long tabLine;
assign tabLine to "{base}:tab:line";
monitor tabLine;
int tabNull;
assign tabNull to "{base}:tab:null";
monitor tabNull;
double tabOffset;
assign tabOffset to "{base}:tab:offset";
monitor tabOffset;
int tabDir;
assign tabDir to "{base}:tab:dir";
monitor tabDir;
int tabExec;
assign tabExec to "{base}:tab:exec";
monitor tabExec;
string tabFilename;
assign tabFilename to "{base}:tab:filename";
int tabLoad;
assign tabLoad to "{base}:tab:load";
monitor tabLoad;
int tabSave;
assign tabSave to "{base}:tab:save";
monitor tabSave;
/* event flags */
evflag efTabLine;
sync tabLine efTabLine;
evflag efTabNull;
sync tabNull efTabNull;
evflag efTabOffset;
sync tabOffset efTabOffset;
evflag efTabDir;
sync tabDir efTabDir;
evflag efTabExec;
sync tabExec efTabExec;
/* other variables */
string pvName;			/* for array pvs */
char *pvBaseName;		/* result of macValueGet("base") */
int port;				/* current port number */
ss testss
	state init
		when()
			pvBaseName = macValueGet("base");
			for(port=0; port<NPORTS; port++)
				sprintf(pvName,"%s:tab:port%d",pvBaseName,port);
				pvAssign(tabElem[port],pvName);
		} state idle
	state idle
		when(tabLoad)
			tabLoad = FALSE;
			pvPut(tabLoad);
			pvGet(tabFilename);
		} state idle
		when(tabSave)
			tabSave = FALSE;
			pvPut(tabSave);
			pvGet(tabFilename);
		} state idle
Prev: A question about new SNL warning messages Janet B. Anderson
Next: Re: SNC crashes William Lupton
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Proposal for boosted Symb device support Joseph P. Sullivan
