Marty Kraimer wrote:
> When you enable the transmit interrupt an interrupt will occur as soon
> as the 1 character transmit buffer is empty, i.e. almost always
> immediately.
There are serial chips which will only generate an interrupt if
interrupts are enabled when the transmit buffer *goes* empty. A driver
for these would have to output the first character from the Write
function, and this is why some drivers work this way. However, if the
chip you have will do it, the approach Marty describes is much cleaner.
-- Andrew
___
.' `. Andrew Johnson, Head of Electronics
/ Royal ) Royal Greenwich Observatory
\ Greenwich Madingley Road, Cambridge, CB3 0EZ
| Observatory Tel: +44 1223 374823 Fax: 374700
+---------- WWW: http://www.ast.cam.ac.uk/~anj
- Re: Greenspring rs422 support Peregrine M. McGehee
- Re: Greenspring rs422 support Marty Kraimer
Re: SNC crashes William Lupton
<1998>
2025
2026
<1998>
2025
2026
