1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: synchronizing client requests & completions
To: "Jeff Hill" <[email protected]>, "'Alan K Biocca'" <[email protected]>
Cc: "Marty Kraimer" <[email protected]>, "EPICS Techtalk" <[email protected]>
Date: Thu, 12 Mar 1998 11:14:46 -0000
Jeff,
> It sounds like your immediate problem is that you need to guarantee
> that a certain set of request have completed before initiating another
> set of requests. It appears that ca_put_callback() will provide proper
> synchronization without resorting to ugly and complex code in your
> client side application.
However, sole reliance on ca_put_callback as a command completion mechanism
may present problems for database designers in regards to lock-set
management since the records dealing with command completion may be linked
with the underlying mechanism database.
Although multiple record solutions create their own difficulties due to
avoiding behavior such as "false NOT-BUSYs" there are ways to mitigate
this. Techniques used in the CAD/CAR model include tracking the CAD record
Client ID field and designing  subsystems so that they transition to the
IDLE state before BUSY when processing new commands.
Aloha,
	Peregrine
Peregrine M. McGehee			Project Engineer: LEDA Control System
(505) 667-3273				[email protected]
LANSCE-8 Controls & Automation	Los Alamos National Laboratory
Prev: Re: synchronizing client requests & completions Peregrine M. McGehee
Next: Re: synchronizing client requests & completions Peregrine M. McGehee
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
