1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: record linking question
To: [email protected]
Date: Tue, 17 Mar 1998 07:52:08 -0600
Ralph Lange wrote:
> SCAN fields are accessible, i.e. you may change it any way you like (CA or
> DB links). Keep in mind that --- as SCAN is of a MENU type --- you will
> have to use the index number instead of the string at runtime.
It is also possible to change any menu type via a DBR_STRING put.
In this case the string value must exactly match one of the menu
choices.
Marty Kraimer
Re: record linking question Ralph Lange
Prev: Re: record linking question Ralph Lange
Next: Re: record linking question Ralph Lange
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
