> Depends on the CA client and how (if) it handles string values. If you use
> the (host side) caput command (from extensions/src/ca) you will get:
> > caput Q5PT1R:rdbk.SCAN ".5 second"
> Old : Q5PT1R:rdbk.SCAN .2 second
> ca_put failed on Q5PT1R:rdbk.SCAN
To write string through using "caput" you have to use the "-s" option,
e.g.
kao 264: caget chademoai2.SCAN
chademoai2.SCAN Passive
kao 265: caput -s chademoai2.SCAN .2 second
Old : chademoai2.SCAN Passive
New : chademoai2.SCAN .2 second
Just type caput it should give you the on-line command syntax
about caput.
Ben-chin
Re: record linking question Ralph Lange
RE: CAMAC problems Garrett D. Rinehart
<1998>
2025
2026
Releasing the source code for CapFast interfaces chong
<1998>
2025
2026
