1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stops in the motor record
To: [email protected]
Date: Mon, 30 Mar 1998 10:37:42 -1000
-- On Mar 27, 1998, [email protected] (Tim Mooney) wrote
> I should mention that glitches on the limit-switch lines can produce
> very similar behavior, and are by **far** the more common cause of it.
> So don't everybody with an intermittently jerky motor immediately assume
> their hardware is flakey.  You might just need some decoupling capacitors.
I'm not sure that this is true.  I've seen this behavior very regularly
(with the .27 release of the motor record, VME8-8 board).  I don't have
any limit switches in my system and limit-switch support has not been
enabled.
It's been a while since I examined this problem, but it appeared to me
to be a "feature" of the OMS board.  It seems that the OMS board
sometimes returns the wrong motion direction when queried, when it is
first starting to move.  I've tried more than one OMS board, with the
same results, so I doubt that it's due to a hardware problem.
My "solution" was to set the RTRY field to 3.  Obviously, this is a
kludge, and a real solution would be preferable, but it seems to have
eliminated the problem for my purposes.
Hubert Yamada, University of Hawaii, Institute for Astronomy
 phone: (808) 956-6648
e-mail: [email protected]
   WWW: http://ccd.ifa.hawaii.edu/~yamada/
Prev: Re: gdct313 problem? Kurt A. Goetze
Next: Re: Stops in the motor record Guy Jennings
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stops in the motor record Tim Mooney
